Hot Forester...
I was towing two cycles on a trailer behind the Forester over the weekend. Everytime I got on one of those long hills the heat gauge would shoot up!
I ended up turning off the A/C and having to run the heat to keep it below the red.
Air temp was low 90's
Are Subarus (Foresters) susceptable to overheating just towing a small trailer up some grades?
Is this common?
On the return trip temp was mid 60's and the heat gauge didn't budge from it's normal spot?:confused:
5 Speed Trans:mad:
What year is it? Is it one of the ones with the dreaded DOHC engine?
Doh!:banghead:
Maybe I should tell you something about this car before I ask stupid questions about it?
2001 Forester 5 speed manuel.
Sorry,
Glenn
82 SubaruHummer
01 Forester
I have 3 words for you,
Red Line Waterwetter
Well, i'd expect it to get hot with the AC on, going up hills, on a hot day, hauling a heavy load...heh.
How heavy was the stuff you were towing?
I was hauling two adults two small kids, gear, two Honda Trail 70 (copies) on a small trailer
It did the same thing last week towing a Hobie Cat
No real weight?
What's Red line waterwetter
Redline water is a additive you can put into your cooloing system that spose to keep the temps around 20 deggres cooler.
I acully wouldent expect the car to get hot pulling a light load (under 1500 pounds) to cause the car to over heat. Ive town loads of 1800 pounds with 5 people in the car with no over heating problems on a hot day in a 1 gen legacy auto. But I never went up a long steep grades.
