headlight problem
do you know for a fact that the light is burned out or does it just not come on?
If the bulb is burned out.... be very careful not to put your fingers on the bulb itself... the oil from you hand will cause it to blow after a short time.
If the bulb is still good but it just won't come on... check the fuses real close.
