headlight problem
i changed the passanger side bulb , the dim was out and the hi beam was ok, ,drove the car a few miles and the low beam is out again , it is a 86 gl spfi a/t sedan , any help ?
do you know for a fact that the light is burned out or does it just not come on?
If the bulb is burned out.... be very careful not to put your fingers on the bulb itself... the oil from you hand will cause it to blow after a short time.
If the bulb is still good but it just won't come on... check the fuses real close.
no i did not touch the bulb , the hi beam worked good just the low beam was out , i will go out and check the fuses
