ThosL Posted December 4, 2023 Share Posted December 4, 2023 (edited) Could a remedy just be keeping the gas cap loose? Edited to add: I'm using a non-Subaru gas cap which may be the issue. I tried loosening the cap, no difference. Edited December 7, 2023 by ThosL Quote Link to comment Share on other sites More sharing options...
montana tom Posted December 8, 2023 Share Posted December 8, 2023 You are not giving us any information. I assume your having trouble filling the tank? If so, your Evap system has issues and must be evaluated. What codes is it throwing? Quote Link to comment Share on other sites More sharing options...
ThosL Posted December 11, 2023 Author Share Posted December 11, 2023 (edited) Hi--I cannot fill the gas intake except very slowly, when forced the gas overflows but most stations have pumps that do not permit that. Edited December 11, 2023 by ThosL Quote Link to comment Share on other sites More sharing options...
azdave Posted December 11, 2023 Share Posted December 11, 2023 I have a vehicle that for years would trip the overfill shutoff at the gas pump for unknown reasons. I found out that if I turn the filler handle upside down, I can pump at nearly full speed without tripping the shutoff. Not sure if that will work for you temporarily until you find out the issue. 1 Quote Link to comment Share on other sites More sharing options...
ThosL Posted December 11, 2023 Author Share Posted December 11, 2023 I think it's something about the evap. canister, the code comes up. Cannot fill reasonably any way. Quote Link to comment Share on other sites More sharing options...
ronemus Posted December 12, 2023 Share Posted December 12, 2023 It can be either the canister or the valve. It's easy to replace both and they're not very expensive, just messy because they're located behind the passenger-side rear tire underneath the car and road filth accumulates on them. 2 Quote Link to comment Share on other sites More sharing options...
ThosL Posted December 12, 2023 Author Share Posted December 12, 2023 So I'll probably have to go to the junkyard. The pollution device in that area is also not working but since it does not affect performance have not devoted attention to it. Quote Link to comment Share on other sites More sharing options...
Steptoe's photos Posted December 13, 2023 Share Posted December 13, 2023 On 12/12/2023 at 8:39 AM, azdave said: I have a vehicle that for years would trip the overfill shutoff at the gas pump for unknown reasons. I found out that if I turn the filler handle upside down, I can pump at nearly full speed without tripping the shutoff. Not sure if that will work for you temporarily until you find out the issue. I used to see this trick done 40 years ago on problem fillers Quote Link to comment Share on other sites More sharing options...
ThosL Posted December 14, 2023 Author Share Posted December 14, 2023 The gas just spills out when I jigger the gas fill handle to pump out more, so not the shutoff. Quote Link to comment Share on other sites More sharing options...
czny Posted December 14, 2023 Share Posted December 14, 2023 Have you checked the fuel vent pipe and hoses for kinks or dents. All this stuff is behind the passenger side wheel and metal shield. Could be rock/ice damage to fill neck vent tube. If the fuel tank can't vent it won't fill. 1 Quote Link to comment Share on other sites More sharing options...
ThosL Posted December 19, 2023 Author Share Posted December 19, 2023 I don't drive on dirt roads where the fuel vent pipe would get crimped, etc.. Only in last six months have I had this problem. I tried to eyeball the critical area, hard to get access. Quote Link to comment Share on other sites More sharing options...
