tol2 Posted August 6, 2004 Share Posted August 6, 2004 I've just purchased the 99 Forester with the Code Alarm security system. I'd like to make it silent, i.e. no chirps will be heard when I lock/unlock the doors. Does anyone know how to set this? Thanks! Quote Link to comment Share on other sites More sharing options...
Cougar Posted August 7, 2004 Share Posted August 7, 2004 I'm not sure if your talking about the stock system or not. I would check the owners manual if you have it and the stock system. Quote Link to comment Share on other sites More sharing options...
DaveWV Posted August 7, 2004 Share Posted August 7, 2004 I think you have to hold both buttons down on the key fob for a certain number of seconds. It was in the owners manual I think. Quote Link to comment Share on other sites More sharing options...
tol2 Posted August 8, 2004 Author Share Posted August 8, 2004 The problem is that although the security system looks like the Code Alarm CA110 model, apparently it is not - the basic functions descriptions in the 99 forester Owners Manual and CA110 Owners Manual don't match... Quote Link to comment Share on other sites More sharing options...
hohieu Posted August 8, 2004 Share Posted August 8, 2004 I see nothing in the operator's instructions for the OEM system about disarming the chirps that you hear when locking and unlocking the car. I also have an alarm system in my car, and there is a horn-shaped plastic siren mounted under the hood toward the rear passenger side. You could disconnect the wires to the siren or checkto see if there is a seperate fuse that you could remove to disarm the it; this would also disarm the the alarm but probably not the starter interupt function. I think you have to hold both buttons down on the key fob for a certain number of seconds. It was in the owners manual I think.In my car, this sets off the panic alarm, which you would presumably do if you were to be mugged near your car. Good luck. Quote Link to comment Share on other sites More sharing options...
The Dude Posted August 9, 2004 Share Posted August 9, 2004 I own a 99 Forester with an alarm system. The is ONE way to stop the alarm from chirping-but it envolves using a hammer. Actually, there is NO way to disable the chirp. That function is found on MY 2000 and up. Get used to it. Quote Link to comment Share on other sites More sharing options...
DaveWV Posted August 9, 2004 Share Posted August 9, 2004 My mistake. I went through my owners manual and the security system booklet and it didn't say how to get rid of the horn chirp. I just cant remember exactly where I read how to do it. But it can be done, I did it. I'll try to remember and I post it. Quote Link to comment Share on other sites More sharing options...
