lagwagon Posted August 8, 2004 Share Posted August 8, 2004 I am tring to learn more about anti sway bars and I found this link ,and I thought some of you would be interested in seeing this formula http://www.kormanfastbmw.com/tantiswa.htm Link to comment Share on other sites More sharing options...
WJM Posted August 8, 2004 Share Posted August 8, 2004 According to that....i increased my sway bar stiffnes by 66874030.497642202400323307325865% or so... seeing as I had 0MM sway bar in the rear...but since you cannot divide by zero...i div by 0.000000000000000000000000001. but the smallest aval. was a 12...so... that number is 7.716049382716049382716049382716 that 18 vs 19 is 1.2414361377838744093888126809938 So that 1.24 is 24% So whats my number? 671%? or just 71%? Or 771%...? Link to comment Share on other sites More sharing options...
lagwagon Posted August 8, 2004 Author Share Posted August 8, 2004 I think it's a formula that shows you how much gain in stiffness you will attain realative to your previous sway bar diameter is proablely acurate.I could see a 19mm feeling 24% stiffer than a 18mm.I'm not sure what you're previous size was relative to your current size but I guess 671% stiffer would be correct. So your new set up is 6.71 times stiffer. Ouch that seems pretty stiff. If you look at some of the other tech info pages on that site it has a cool page that explains the effects of Sway bars and tire pressure on oversteer and understeer. Link to comment Share on other sites More sharing options...
