SuspiciousPizza Posted March 26, 2025 Share Posted March 26, 2025 I currently have my GL all torn apart to address some well entrenched gremlins. The main issue I have a question regarding is why does my fuel pump bog and whine when I use my turn signals? Fuel pump operates as it should (although I don't have a fuel pressure gauge hooked up at the moment, I will be adding several gauge pods, including a fuel pressure gauge, once I get the engine back in my car.) However, whenever I used my turn signals my fuel pump would whine a different tone only when the turn signals blinked. Between blinks it would have a normal tone. The negative terminal arcs when I plug in the battery, indicating a short (?) Obviously I'd assume it's a wiring or ground issue (almost all the grounds in the engine bay were caked in oil, grease, and dirt but I've been thoroughly cleaning the engine bay with Simple Green and a multi-pack of tooth brushes while I have the space to do so.) Would anyone have any pointers? Would I be able to use the fuse box to check which circuit is shorting? I can read a multimeter, have a very basic understanding of circuitry and have a full set of service manuals at my disposal. Thanks! :] Link to comment Share on other sites More sharing options...
el_freddo Posted March 27, 2025 Share Posted March 27, 2025 An aftermarket head unit will always create a tiny spark when connecting the battery. Other than that the fuel pump issue is either a poorly operating alternator, old wiring with resistance points or a battery that isn’t coping as well as it used to. Lastly could be some sketchy wiring done by a pervious owner. You’d really need to check out if anything was modified before your ownership. Eg: I have a Gen1 RS turbo Liberty (Legacy over your way) that someone used the door switch circuit as the earth for the aftermarket head unit. Whenever someone opens a door the headunit turns off as the circuit becomes active. Classic (*facepalm*). Cheers Bennie 1 Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted March 27, 2025 Author Share Posted March 27, 2025 I do have an aftermarket radio, and it's an absolute rat nest underneath the steering column and behind the glovebox. I figured this was a good candidate to begin diagnostics. There is plenty of wire nuts, misc wire gauges, and "good enough" wiring *facepalm* indeed. Would anyone have a wiring diagram for an '89 radio? I don't even know which model of radio came with the car from factory, let alone the wiring. Alternator does seem to be pushed pretty close to its capacity, but I'm not convinced it's the alternator. Voltage drop during turn signal flashes is 2-4 volts according to the volt meter in the gauge cluster, a big drop. Alternator is a Nissan Maxima VG30E alternator mod. Pretty commonplace. :] Link to comment Share on other sites More sharing options...
azdave Posted April 8, 2025 Share Posted April 8, 2025 I've had several pumps in my 87 DL wagon in the last two years and they all begin to whine and moan after a few months but only when they get warm. The whine pulses up and down when the turn signals are on or when any change is made to the loading on the battery. The pumps all work great at first and are pretty quiet but eventually I begin to hear them after a long drive home from work. I just figure it is cheap pumps that quickly lose the gearing tolerance after a few thousand miles. 1 Link to comment Share on other sites More sharing options...
bushytails Posted April 9, 2025 Share Posted April 9, 2025 (edited) Battery voltage fluctuating with the turn signals is normal. The two 1156 bulbs draw about 5A when hot (~27W each), and at least double that cold, i.e. every time they blink on. The stock alternator is 55 or 60A iirc. You're pulling surges of a quarter of its high-rpm rating, and you're at idle (since you can hear the fuel pump) where it can barely keep up with the loads anyway. And when the voltage dips, the fuel pump slows down. A spark when connecting the battery is also 100% normal, and does not imply anything wrong, modified or otherwise. You're charging the capacitors in every electronic module, including the radio, ECU, fuel pump controller (I can't remember if that year has one or not), cruise control module, etc etc. Edited April 9, 2025 by bushytails 1 1 Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted April 10, 2025 Author Share Posted April 10, 2025 On 4/8/2025 at 9:13 PM, bushytails said: You're pulling surges of a quarter of its high-rpm rating, and you're at idle Ahhh, I see. I'm mechanically-minded so electronics isn't my forte but I can wrap my head around it. Thank you for the explanation I didn't realize RPM correlated with current. I'll be installing a '90 Loyale radio/cassette deck and removing my rear speakers in hopes to mitigate the whine *it's annoying*. Stock radio is 10 or 15W and my aftermarket was 50W. On 4/8/2025 at 9:13 PM, bushytails said: You're charging the capacitors in every electronic module Also makes sense. Thanks again. :] Link to comment Share on other sites More sharing options...
scoobydube Posted April 12, 2025 Share Posted April 12, 2025 My first fuel pump broke down at 150,000 miles. My second fuel pump is still going strong at 380,000 miles but I carry a backup. In my experience, when the engine ground wire from the left cam cover by the battery, to the ground on the frame, becomes rock hard at the connection to the frame at 250,000 miles, multiple accessories will cause the engine to run rough. So you may have a bad ground wire. I run two ground wires at the same location because I am so paranoid of it happening again and at the worst possible location. Used fuel pumps from U-pull-it are fine if the car was not sitting for years before they sold it off to the yard. And they are cheap. As are the ground wires. Link to comment Share on other sites More sharing options...
azdave Posted April 14, 2025 Share Posted April 14, 2025 Here's a new thing to check for if you've come here searching for "fuel pump whine" issues. This relates to a whine that is barely noticed at first but gets worse the longer you drive and yet is quiet starting out the next day. SPOILER ALERT! I thought it was the pump getting too hot the longer it ran but it was actually being starved for fuel. I went to test a new pump on my DL but when I pulled the inlet line to the the pump, fuel barely dribbled out. It should have given me a bath because the tank was at least 3/4 full. I decided to take a look at the inline fuel filter I added a few years ago, just ahead of the pump. Sure enough, the filter was barely passing fuel. I cut it open and found the pleats completely packed with a light gray powdery paste. After the fuel evaporated, the stuff was very loose, fluffy and powdery, almost like talcum powder. I don't recognize it as any type of fuel tank oxidation or corrosion I have seen before and I play with classic cars constantly. I'm used to seeing rust flakes or gelled gasoline gunk but not this weird powder. It was not magnetic. It sank to the bottom quickly when I added gasoline to the powder and stirred it. When I pulled off the filter, I found once again that hardly any fuel was coming out of the line so guessed the filter sock on the end of the pickup tube was clogged too. As a test, I removed the gas cap, to try to relieve any possible vacuum, but that changed nothing. Next, I blasted a bit of compressed air backwards into the line from the tank and after that, I was greeted with my expected gasoline shower and the full flow was restored. I now need to drop the fuel tank and do a flush and inspection to see where this powder is coming from. I might be better off to remove the filter sock from the pickup tube before I install the tank and then be sure to change the external fuel filter every 5000 miles or so. At least that way, I would not have to drop the tank again if the powder continues to be an issue. Link to comment Share on other sites More sharing options...
