tire size, increase size
Have an 08 Outback, with stock 225 X 55 X 17 tires. I would like to install taller tires to gain a little more ground clearance, and with taller side walls get a smoother ride. How large can I go without causing interference with body or chassis? Thanks, Larry
Look at the clearance between the tire and the front spring perch - in all the Subarus I've owned there hasn't been much.  I think you'll find that the small increase you could get would have no real impact.
