Rooster2 Posted May 31, 2025 Share Posted May 31, 2025 Have an 08 Outback, with stock 225 X 55 X 17 tires. I would like to install taller tires to gain a little more ground clearance, and with taller side walls get a smoother ride. How large can I go without causing interference with body or chassis? Thanks, Larry Link to comment Share on other sites More sharing options...
ocei77 Posted May 31, 2025 Share Posted May 31, 2025 this may help https://www.wheel-size.com/calc/ O. Link to comment Share on other sites More sharing options...
ronemus Posted June 1, 2025 Share Posted June 1, 2025 Look at the clearance between the tire and the front spring perch - in all the Subarus I've owned there hasn't been much. I think you'll find that the small increase you could get would have no real impact. Link to comment Share on other sites More sharing options...
