lmdew Posted Sunday at 08:57 PM Share Posted Sunday at 08:57 PM Well, enough to get the horn to work, which was needed to pass the Safety Inspection. They had failed my 2002 Impreza wagon for no horn. I provided a ground at the under dash connector and it worked fine, so continued up to the steering wheel. No continuity between the lower dash connector and the horn wire. That pointed to the clock-spring. Being in Hawaii and with limited parts I pulled it apart. careful taking it apart gave me access to the spool of wire ribbon that makes up the clock-spring. Sure enough close to one end it was toast. I cut it back a couple of inches and stripped off the insulation with a razor blade. That allowed me to tuck the copper leads into the connector for the horn. The airbag was out of it already and I sure would not have done this repair if I wanted the airbag to work. I just needed a horn for the island beater. 2 Link to comment Share on other sites More sharing options...
el_freddo Posted Sunday at 11:37 PM Share Posted Sunday at 11:37 PM I need to do this for our Gen3 Liberty - the cruise control no longer works. Not complaining at 500,000km. My thought was to pull one from a lower km unit at a wreckers and swap them over - let the airbag power down for several hours before pulling the airbag out to access the steering wheel retainer nut. @lmdew - are you based in Hawaii? For some reason I thought you were on the mainland… Cheers Bennie Link to comment Share on other sites More sharing options...
lmdew Posted 15 hours ago Author Share Posted 15 hours ago Colorado and Hawaii. Welcome in both. 1 Link to comment Share on other sites More sharing options...
