SuspiciousPizza Posted August 15 Share Posted August 15 For SPFI models, the fuel pressure discharge from the fuel pump is 36-50 psi. After the regulator is 20-24 psi @ 700rpm. The regulator drops the high pressure from the pump to a usable pressure for the injector. So there is a high pressure side and a low pressure side, separated by the fuel pressure regulator on the throttle body. Could be an issue with the fuel lines or filters. But most likely the fuel pump is tired and out of spec. Link to comment Share on other sites More sharing options...
cherrythesubaru Posted August 15 Author Share Posted August 15 Well wish I had done this check sooner! I'll see if I can find a pump and swap it out. Thanks! Link to comment Share on other sites More sharing options...
cherrythesubaru Posted August 15 Author Share Posted August 15 Searching around for a pump that will work. My local parts store carries this pump: https://www.rockauto.com/en/moreinfo.php?pk=1111648 Thoughts on this being a viable replacement? Link to comment Share on other sites More sharing options...
el_freddo Posted August 16 Share Posted August 16 I don’t know the SPFI well at all, are you sure the fuel pressure spec is 21psi? I thought it would be more inline with other EFIs like the EJs up at about 40psi. I’ve used the same external fuel pump for a NA MPFI EA82 and an EJ22. No issues. My thinking is that your fuel pressure is half of what it should be. This could be the fuel regulator or the fuel pump itself, or both. Pull the vac line for the fuel pressure regulator and make sure it doesn’t smell of fuel. If so, it’s dead. Cheers Bennie Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted August 16 Share Posted August 16 Yeah that pump should work. Really so long as the pressure, voltage, and current draw are correct (the pump you showed looks to meet those specs) then these cars really don't care. I don't know if it'll last as long as an OEM or equivalent pump but it'll do the job. You may have to do some electrical work and figure out a mounting solution since this isn't an OEM equivalent pump but that's not a big deal and it's nothing too complicated. Sadly OEM/equivalent SPFI pumps are NLA but if you do ever want to keep a lookout for one, the part number is 42021GA242. Good luck, let us know how it goes. :] 1 Link to comment Share on other sites More sharing options...
cherrythesubaru Posted August 18 Author Share Posted August 18 Ok got that pump installed. Still only getting 19/20psi from it though... going to inspect my fuel lines and blow some air through them to see if there are any blockages. Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted August 18 Share Posted August 18 Did you check that fuel filter down near the fuel pump? Too bad you had to go buy that pump but it'll give you more peace of mind in the future. Plus you can keep your old one in the car as a spare if you're ever in the situation you need it. If you do have to replace any rubber fuel hoses, Codan makes hoses that are the right diameter and are very good quality. Check out Volksbolts, they've got a good write up on fuel hoses. If you ever need some reading material. Link to comment Share on other sites More sharing options...
cherrythesubaru Posted August 19 Author Share Posted August 19 I believe my model only has one fuel filter in the engine bay which I swapped out. I blew out the hoses with compressed air and reconnected. Didn't seem to make any difference. Out of curiosity, I pinched the outlet hose on the pressure regulator with my pressure gauge still attached (in line after the filter but before the regulator) and was able to get a reading of 40psi. With this in mind, could there be an issue with the fuel injector being stuck partially open and not allowing enough pressure to build for a correct psi reading in front of the regulator? Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted August 20 Share Posted August 20 I checked the troubleshooting table in the FSM for "Engine stalls after initial combustion". All the following are what it says for the fuel injector: Poor contact at terminal (could be at the injector connector itself, an issue with the wiring in the harness, poor connection at the wiring harness connectors (large black connectors near the driver side strut mount), or poor connection at the ECU. Performance characteristics unusual (maybe the mesh "birdcage" on the injector is dirty or it's sticking.) (To check if it's sticking, place the business-end of a screwdriver on the metal body of the injector and put the handle on your ear. Put voltage to the injector BRIEFLY LESS THAN A SECOND and listen for the "click-click". One click for power on, one for power off.) Clogged filter. I'd check the injector, mate. You've got a good pump, lines are clear, new filter, good regulator. Really the only other component in that fuel circuit is the injector. Maybe the mesh birdcage sieve is dirty? Either that or the injector is borked? Injector resistance should be between 0.5-2ohm (measured on the connector on the injector). If the injector tests okay and is clean on the sieve/not sticking, check the engine harness for damaged wires or poor terminal contact. (I doubt it's a contact since squeezing hose has nothing to do with electrons) :] Link to comment Share on other sites More sharing options...
el_freddo Posted August 20 Share Posted August 20 When squeezing the return line and getting the higher psi reading, how does the engine run? Better or worse? Cheers Bennie Link to comment Share on other sites More sharing options...
cherrythesubaru Posted September 4 Author Share Posted September 4 FOLKS! We have liftoff!!! Cleaned the injector with some carb cleaner and reinstalled. Still had some intermittent issues with misfires but I was able to play around with the distributor timing and took the beast for a rip around town last night. Engine is running great! Next up, suspension and brakes. 1 Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted September 4 Share Posted September 4 Congrats man, glad you're keeping it on the road. For suspension work, check out King Springs, they have overload springs that stiffen the suspension up quite a bit. Kind of a rough ride but allows for more cargo capacity and handles better. You may have a tough time finding front struts. But they're out there if you keep your eyes open and have patience. Their availability seems to come in waves. Also check out DRW bushings, good polyurethane bushings made by a very small business. If you ever need parts you can't find, I have a local parts guy I plan to visit in the next few weeks. Shoot me a PM if you need anything. :] P.S. you plan on doing wheel bearings while you're in there doing brakes? Link to comment Share on other sites More sharing options...
cherrythesubaru Posted September 4 Author Share Posted September 4 Cheers! With the lift on this thing, I'll probably have to do some more searching for parts that will fit. I'm thinking I'll do a full overhaul of everything to do with suspension, wheels, brakes, potentially steering. We'll see how the part search goes! Appreciate the offer to help find parts from your local guy. Will PM you when I'm in search mode! Link to comment Share on other sites More sharing options...
scoobydube Posted September 24 Share Posted September 24 If you are getting the "beep of imminent death" from your ECU, when driving around, or even on startup, then your timing has issues. Various issues include, 1. rotor screw dropped out, 2. timing belts have never been tightened which should be done every 5000 to 8000 miles, 3. one side has skipped a tooth due to loose timing belts. Other symptoms include, engine power fluctuating, idles at a lower rpm than usual, less than normal power, runs rough on startup, heavy valve lifter noise. All of these indicate a timing issue. Link to comment Share on other sites More sharing options...
scoobydube Posted October 18 Share Posted October 18 The trip computer beep also comes on when your power steering fluid is very low. Link to comment Share on other sites More sharing options...
