lmdew Posted July 26 Share Posted July 26 I had it service Nov 2024 after replacing the Evaporator due to a leak. Worked great till the other day. Then NO AC. No leaks and when I hook up the cheapo service gauge pressure is High, in the red. I pulled the AC Relay and jumped it. AC compressor kicked in and the gauge went into the green. I'll take it back to the service location, just thought I'd put this out there to get your thoughts. Thanks, Larry Link to comment Share on other sites More sharing options...
88SubGL Posted July 26 Share Posted July 26 13 hours ago, lmdew said: I pulled the AC Relay and jumped it. AC compressor kicked in Was the air in the cabin getting cold? If so, it sounds like something in the wiring or possibly a low pressure switch, but I’m not an a/c tech by any means. Link to comment Share on other sites More sharing options...
nvu Posted July 26 Share Posted July 26 If it's the single gauge one on the low side only. Yes it would read high, around 80-90psi when the system is off. Not much else to add about why it's not kicking on, but it's normal to see it high on a single gauge reading. Thinking it's more electrical than a system problem. Did you swap the relay with a similar one on the car yet? Link to comment Share on other sites More sharing options...
lmdew Posted July 26 Author Share Posted July 26 Yes swapped the relay no change. I'll dig into it a bit more. When I jumped the AC and the compressor kicked on it was getting cold. Thanks Link to comment Share on other sites More sharing options...
nvu Posted July 27 Share Posted July 27 (edited) If it's the old school manual air, check the pressure sensor. It's somewhere on the condenser high line. Short it and see. The temperature sensor is some feedback transistor, you can't short it to test. Unlikely as it only cuts out when the temp is too cold. Unlikely the AC switch itself is bad, you can bypass it and force AC on by turning to full defrost. No idea where to begin with the auto climate control, never had to deal with one. Edited July 27 by nvu Link to comment Share on other sites More sharing options...
lmdew Posted July 27 Author Share Posted July 27 Thanks. Link to comment Share on other sites More sharing options...
lmdew Posted July 28 Author Share Posted July 28 Pressure switch is forward just off the condenser in the HP line. I unplugged it, jumped it the plug and the AC worked. Plugged it back in and the AC works. A little corrosion cleaned maybe. It's so tight up front you can't see the connector very well. We'll see what happens! Thanks to all. 2 Link to comment Share on other sites More sharing options...
88SubGL Posted July 29 Share Posted July 29 Glad you got it worked out. To hot not to have a/c. Link to comment Share on other sites More sharing options...
