OBD 2 Scan Tool/Veepeak Dongle Won't Connect to ECU
I have a 1982 VW Vanagon with a 2.5 Subaru conversion. Need some help getting my OBD 2 scan tool/Veepeak dongle to connect with the ECU. The van came with a Veepeak OBDCheck BLE and on my phone I am using Car Scanner. Given the van came with the Veepeak dongle, I am presuming that at one time it all worked. The Veepeak dongle does work fine on my 2011 Dodge Ram.
I have checked for 12V at pin 16 and ground at pins 4 and 5, all good. I do have an aftermarket radio but I can’t see it connected to any K Line; my voltage at pin 7 is less than 9 V so even if that was the case it would apparently be fine. I have replaced the OBD 2 port with a new one to ensure the pins are connecting well.
Would really like to get this working for both diagnostics and dashboard instrumentation. Any thoughts?
What year is the donor vehicle and engine management system from?
Stop by an auto store and ask them to try reading it with their scanner.  If they can, at least you know the wiring is good.
