92 Loyale clicking during acceleration after replacing front cv axles
Just replaced both front cv axles on my lifted 92 Loyale (5spd manual 4wd) and I'm getting some nasty clicking/clunking noise multiple times per rotation during acceleration straight or on turns. There is no noise while coasting in neutral.
I used aftermarket axles as the originals had already been replaced and the axle lengths seemed to match what was already on the vehicle when I bought it.
Could this just be a result of using shitty aftermarket axles that can't handle the angles of the lift? What should I check for potential issues caused by errors during install?
How high is your lift? I've heard 2" is about the limit of the axles but I'm not experienced in lifting these cars so other's experiences may differ.
It seems to be the general consensus that aftermarket axles aren't worth running if it's avoidable.
If anything, check out the grease in the joints. I highly doubt they'd assemble them dry but knowing the quality of modern aftermarket parts for these cars, it also wouldn't surprise me.
I'd try packing the joints with a good quality grease and seeing what happens. I recommend Yamalube Molybdenum Disulfide grease. It comes in 4.5oz bottles which is the perfect amount for one joint. I squeeze out as much as I can into the joint, then I cut the bottle open and scoop the rest into the boot. It's expensive but it's very good grease.
Try looking out for used OEM axles. It's a pain to track the right axles down but if you run them with good grease and quality neoprene boots they should be just fine.
It's kinda hard to know what's up without being in the car, but some other things that make noises...  most of which I've seen before...
Does the noise get worse when turning?  If not, it's not outer CV joint angles.  I've only broken one joint from exceeding its angle, and it was flexing the suspension while at full lock.
Does the noise go away if you have a passenger (or 300lbs of bricks, or something) in the front seat?  If not, it's probably not inner cv joint angles.  Feel if the shaft can wiggle in and out a bit, or if it's jammed up against the side of the cup.  Wiggle the inner cups up and down to make sure they're free on the splines, not jammed downwards by the shaft.
Bad wheel bearings or loose wheel hubs (the hub nut needs quite a bit of torque), causing brake rotor to clip caliper bracket.  I've seen this a half dozen times...  Also make sure no gremlins stole the cone washers when you were putting it back together.  Jack it up and make sure you can't wiggle the wheels in any direction.  Lug nuts are tight too, right?
Bad transmission; differential going out.  Not sure how to diagnose this one.  I haven't seen it myself, but I've heard of it for that year range, especially on full-time transmissions.  Does it do it in reverse too?
Worn transmission stub shaft splines causing the inner cups to flop around.  I've only seen this cause vibrations, but noise is possible too.
Bad driveshaft u-joint.  Probably not if it's a part-time transmission; possible if it's a full-time.
Broken transmission or engine mounts (including pitch stop), and you're hearing the transmission banging the crossmember or tunnel or such.
Wrong axle length, I guess,  Never seen it, but it's a possibility.  Hop on the fender while watching the shaft, and make sure it can move in further than the resting position.
Defective axles.  Some of the chinese ones are really crap.  I have GSP ones now and they seem better than the other chinese brands I've used.
I’d put my money on the aftermarket shafts being the issue.
Been there a few times ;(
I do like the suggestions from bushytails. As for the front diff issues, I’ve never seen an issue with the manual transmissions and their front diffs.
