Turbone Posted Wednesday at 01:19 AM Share Posted Wednesday at 01:19 AM I did a EJ22 (complete engine rebuild) swap on a friends 87 GL10 and the things been giving us grief. Its running real rich and dumping fuel and fouling the plugs. I've checked fuel pressure, its good. Comp on all cylinders is over 200 (rings have extra gap for NA/T in the near future. Its also hard to start and runs rough for several seconds, then smooths out. Has a little bit of a surge too. Non EGR and have replaced the fuel reg. Looking for a little guidance on where to look next, should I start going thru the wiring harness next? Link to comment Share on other sites More sharing options...
Numbchux Posted Wednesday at 05:44 PM Share Posted Wednesday at 05:44 PM What year engine/wiring/ECU? What transmission does the ECU think it has (I assume it's a manual now)? Correct MAF sensor, IAC, TPS etc.? DTCs? I'm having the thought that hoses might have been switched and excess fuel is ending up in a vacuum line. But if it's getting pressure and running at all, I can't think how. Maybe return line right off the rail to a vacuum source? I'm just thinking out loud at this point. Or maybe temp sensor reading super cold? I know on our 04 EZ30 Outback, when the wires to that got chewed, it defaulted to 40*F. But it was about 10 below that day, so it would not fire. But maybe a short might make it read crazy cold? Link to comment Share on other sites More sharing options...
Turbone Posted yesterday at 03:41 AM Author Share Posted yesterday at 03:41 AM Just replaced the temp sensor, no change. Everything is from a 92 Legacy with original parts, with a stock 5spd D/R trans I might take another look at the return line Link to comment Share on other sites More sharing options...
Turbone Posted 4 hours ago Author Share Posted 4 hours ago Another bit of info. We used custom made headgaskets from Cometic. Cant remember the exact thickness, but they were made thicker for future NA/T application. Link to comment Share on other sites More sharing options...
