Why is my turn signal blinking double speed? No bulbs burned out?
2002 Legacy, the right turn signal blinks double speed, but both the front and rear bulbs are flashing, looks the same as the front and rear bulbs on the left, which flash at normal speed.
I'm accustomed to fast flashing means a bulb burned out, but none of the bulbs seem to be burned out.
Anyone have any idea what's going on?
The socket for the front turn signal is defective, won't make consistent contact with the bulb. The socket unplugs from the harness, but I can't find a replacement. Does anyone have a source for that? It takes an 1156 single filament bulb on one end, and has two prongs to plug into the wiring harness connector on the other.
