SuspiciousPizza Posted December 2, 2025 Share Posted December 2, 2025 Coming home from work this weekend I smoked a deer. Luckily my headlight took the brunt of the impact but the deer spun around and caved in my driver side door. It ripped off some of the side protectors and damaged the protector on my door. I'm talking about the 2.5" wide black plastic pieces. Are these pieces held on with plastic clips/rivets or maybe a double sided tape? How would one remove them? I'll be installing a "new" door in the coming weeks and once I get my hood straightened out I'll be back on the road. Next summer I'll get my door fixed and a buddy and I are going to repaint the car. I also will be welding a bull bar from chrome moly tubing so I don't have to worry about deer as much in the future. Thanks :] Link to comment Share on other sites More sharing options...
el_freddo Posted December 3, 2025 Share Posted December 3, 2025 Those strips are held on with plastic clips. Best way to remove them is via the inside of the door by squeezing the tabs closed to let them slide out the hole. You don’t need a chime moly bullbar - that will fold something more substantial in the engine bay. What you want is a bullbar that will bend a bit as it absorbs the energy of the animal - thus saving other factory parts on the car that are harder to come by. Nothing is certain pin this though. Maybe a full exo-cage will do the trick, but where do you draw the line? Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted December 3, 2025 Author Share Posted December 3, 2025 I've been looking at the rally Leones and their brush guards and I was thinking something inspired by that. Something that mounts to the bumper and wraps around the side to cover the running lights. I'm buying a spare bumper from my parts guy so I don't have to modify my factory bumper. I plan on using industrial rubber vibration dampeners (originally designed to be placed between heavy machinery and a concrete pad to absorb vibrations). Hopefully these will act as a bushing to absorb impact. Otherwise I'd have to figure out some sort of suspension system for it. The rubber dampeners seemed to be the simplest solution. Otherwise I could make the mount out of aluminum tubing and bolt that to the chrome moly guard. The aluminum would act as a sacrificial absorber. 1 Link to comment Share on other sites More sharing options...
bushytails Posted December 6, 2025 Share Posted December 6, 2025 The factory option bullbar is impressively flimsy. It would not provide any protection against hitting anything larger than a flying squirrel. I assume it's to keep weight down. I broke mine using it to pull myself up from a kneel... The plastic clips holding the trim on are likely very brittle. Be careful removing them. Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted December 6, 2025 Author Share Posted December 6, 2025 I got a bumper but the only one available is in very rough condition. The car it came off of clearly had a front end wreck. The metal has a lot of deformations. So I may not use the metal of the bumper. I'm thinking a rectangular tube structure that uses the bumper mount locations. The bull bar is mounted to this structure with the bushings. Then I'll modify the plastic portion of the wrecked bumper to fit over the rectangular tube structure. This way it looks like the factory bumper, but it uses a different metal reinforcement. I'd probably make this out of aluminum. I cannot find the clips on the inside of the door. They're covered by a stamped piece of metal that runs the length of the door. Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted December 11, 2025 Author Share Posted December 11, 2025 (edited) Last night I managed to repair my grille that most would have looked at and considered a total loss. The deer hit the corner of the grille and shattered it like glass. Luckily my lower valence panel caught almost all the pieces. All you need for this repair is a bottle of THF (a chemical used as a precursor for polymer synthesis) and some applicator bottles with needle tips. The THF will wick to into thin cracks where it then melts the top layer of plastic. After the solvent dries, the molten plastic molds together forming a chemical weld. To better understand and visualize this process, look up how model builders weld their models. It's the exact same process. You could also use this process to repair interior or exterior trim pieces. THF works with most plastics but it does NOT work on polypropylene (PP). Look for the plastic composition molded into the piece you're working on. For polypropylene your best bet is using an adhesion primer along with CA glue (super glue). :] Edited December 11, 2025 by SuspiciousPizza It's like Japanese Kintsugi, but for plastic. Extra points if you can dye the repair sites gold. Link to comment Share on other sites More sharing options...
88SubGL Posted December 11, 2025 Share Posted December 11, 2025 2 hours ago, SuspiciousPizza said: look up how model builders weld their models That was what I was thinking about as you described the process. Link to comment Share on other sites More sharing options...
