August 26, 200421 yr has anyone ever had problems with their o2 sensors, because i am going to buy this 88' gl-10 turo. The owner says that it has a bad o2 sensor and it causes it to burn off fuel when it starts and spew a bit of black smoke. is that a problem with the o2 sensor? is $300 a good deal for the gl-10 with 178k and an auto tranny? post any thoughts please
August 26, 200421 yr could be the o2 sensor I suppose $300 is not bad at all if its running / driving / tagged For the best ownership experience, I would suggest doing some major maintenence right from the get go. Timing belts water pump radiator hoses belts radiator flush/repair/replace reseal cams/crank/oil pump
