Recurved Distributors
Hey all,
Those of you with a recurved distributor, can you post up your results with it and how you like/liked it? I've read 3 different threads with a mention of it in it (2 of them by General Disorder) but nothing more than just a mention of it. Ram Performance (http://www.ramengines.com) says this----->
"Recurving the distributor properly will add 13ft.lbs torque and aid in idle control."
That's a lot of torque for an EA81 engine. I'm not sure if they are talking about a highly worked/modified one, a stock one or both.
Can anyone with experience in this area enlighten me/us? Thanks!
three letters....D I S!!!!
Ive not had mine re curved....but I always mess wid the timing.......
Here is one you can recurve as often as you like:
Megajolt lite - will control the ford edis system
http://picasso.org/mjlj/
Or you can go full bore, and do the fueling and ignition w/ megasquirt & EDIS
http://www.jsm-net.demon.co.uk/megasquirtnedis/index.html
or here for lots of MS info:
http://www.msefi.com/
Soon...I will be running this on my XT. Goodbye crap MAF flapper door, goodbye broken vacuum advance canister distributor woot!
