Do It Sidewayz Posted October 23, 2004 Share Posted October 23, 2004 i think i remember someone saying that newer style Subaru strut tops were the same as EA82 cars...is this true?? we've had 2 stock strut mounts come apart on our ice racer. Both...the rubber separated from the metal, and then ended up dropping right out the bottom and were in the fender well. I don't see people with Imprezas and wrx's having this problem. What fits?? i'm looking into getting some GC8 or Group N strut mounts. As they need to look stock on the car as were running production. Quote Link to comment Share on other sites More sharing options...
Turbone Posted October 23, 2004 Share Posted October 23, 2004 I havent seen any people with Imp's and WRX's ice racing either I'm pretty sure you will need to do a 5 lug swap if you want to use the struts and stuff from a Impreza. Quote Link to comment Share on other sites More sharing options...
Do It Sidewayz Posted October 23, 2004 Author Share Posted October 23, 2004 I havent seen any people with Imp's and WRX's ice racing either I'm pretty sure you will need to do a 5 lug swap if you want to use the struts and stuff from a Impreza. it's actually not a concern for ice racing. I'm building a 1985 Subaru RX for Performance Rallying. I'm worried about them coming apart from the beating they take while rallying. I just want to replace the Strut Tops (mounts...the rubber/metal mount with 3 bolts) I already have a custom built bilstien coil-over set-up in the works. Quote Link to comment Share on other sites More sharing options...
