October 24, 200421 yr The check engine light on my recently acquired 90 Legacy lights up about 10 minutes after starting the vehicle. Sometimes it stays on, while at other times it goes out again. The car runs fine and everything seems normal. How can I troubleshoot this? Do I need a special tool to read diagnostic codes? Thanks for any suggestions.
October 24, 200421 yr There Was A post out there about this... But i cant find it... So heres the link on what to do!! Very Good Site.. http://www.surrealmirage.com/subaru/subaru.html Hes in here all the time.. I just did this tonight after i read The post!! Very cool.. I have a 12 code.. starter issue.. BUt ya read that, it you should find out what is wrong!
October 24, 200421 yr Turn car off Plug the 2 black harness' togheter under the dash (between TCU and ECU) Turn car to ACC position (do not start) CEL will blink the codes. Unplug harness Fix the problem Put many more miles on your car.
October 25, 200421 yr Author Thanks for the replies. I'll try reading the codes in the next few days and post my findings.
October 28, 200421 yr Author OK - I finally got the car from my 16 year old son and a day off to read the codes. I had to let him drive my 2002 Tundra to school today though! Anyway, I connected the 2 ends of the black connectors using the chart and instructions from http://www.surrealmirage.com/subaru/subaru.html I have 6 codes cycling in this order: 33 - Abnormal reading from vehicle speed sensor 35 - Canister purge solenoid valve inoperative 12 - Abnormal reading from starter switch 21 - Abnormal reading from water temperature sensor 23 - Abnormal reading from air flow sensor 24 - Air control valve inoperative I believe these are historical problems that have occurred and been stored in the diagnostics system. My son had an overheat problem due to the radiator cap not being screwed on properly. And we found a connector on top of the engine, directly behind the air conditioner compressor disconnected. My question now is should I erase these codes and check them again? I believe I may have a truly faulty solenoid valve and/or air control valve, but that the other abnormal readings are just historically stored fault codes. Thanks for the help!
October 28, 200421 yr here was that post you were talking about: http://www.ultimatesubaru.org/forum/showthread.php?p=158817#post158817
October 29, 200421 yr Author Thanks for the replies Legacy777. I erased the codes... twice. The first time I initially got the all clear signal (steady flash at 1/2 second intervals), then started getting something else after about 3 or 4 minutes of driving. The second time I only drove for about 2 minutes and I got the all clear signal only. Then parked the car, turned it off and disconnected the green and black connectors. However, I am still getting all 6 trouble codes mentioned earlier when I connect the black connectors back up. What do you think?
October 29, 200421 yr Are the codes active codes? Like is the CEL blinking while you drive? Or do they just show up again when you check the black connectors? if the CEL isn't on, or blinking while driving, then these codes are probably stored codes, and not active. Try disconnecting the EGI/TCU fuse (which I think is fuse # 14 at the driver's kick panel) for 30 minutes. Drive the car around, and then check codes again.
October 29, 200421 yr Author Your procedure for clearing the alarms from memory call for driving the car over 10 mph for one minute while the black and green connectors are connected. My trip around the block takes a bit longer than one minute. I get the "all clear" if I drive for just 2 minutes. If I continue driving for a couple minutes longer, the "all clear" 1/2 second flash changes to the alarm codes. So, I assume they are active alarms. With the connectors disconnected I get the intermittent CEL like I described in my first post. I also tried resetting the modules using your procedure that calls for disconnecting the negative terminal as well as removing fuse 14 for an hour or so. Thanks again!
October 29, 200421 yr I also tried resetting the modules using your procedure that calls for disconnecting the negative terminal as well as removing fuse 14 for an hour or so. Thanks again! So with the fuse and battery method the codes came back right away?
October 29, 200421 yr Author Yes - That is correct. It seems like they must all be real faullts, but I don't think so. I had thought that some of the abnormal sensor readings would have cleared. Especially the abnormal water temperature. The water temp is okay. I'm pretty certain all those sensors aren't bad either. We have had the car for 2 months and just recently started getting the intermittent CEL indications.
October 30, 200421 yr Author The car runs great. Nothing out of the ordinary, other than the CEL coming on. Oh, there is one thing that I have failed to mention: When I had the black and green connectors connected, the engine cooling fans came on when I turned the key to the accessory position.
November 1, 200421 yr Hi, I would check that the plugs are right in at the computer and that they havent got wet and corroded. It's just a guess but the problems indicated are not really related except that they all come together at the computer.
November 7, 200421 yr I have the same problem with my legacy. Haven't had a chance to check the trouble codes yet. The car runs great, no problems what so ever except for the CEL that lights up sometimes when I start the car. It lights up and stays on. If I shut the car down and turn in back on it sometimes dissapears and sometimes stays. A bit annoying, indeed.
November 8, 200421 yr I have the same problem with my legacy. Haven't had a chance to check the trouble codes yet. The car runs great, no problems what so ever except for the CEL that lights up sometimes when I start the car. It lights up and stays on. If I shut the car down and turn in back on it sometimes dissapears and sometimes stays. A bit annoying, indeed. check the codes and let us know what you find.
May 14, 200520 yr Author Sorry I took so long to post back, but the problem is fixed! The computer was faulty. I replaced it and all codes are gone! Thanks for the replies.
May 14, 200520 yr Thanks for posting back! I still haven't been able to figure out the problem so maybe it's that.
