rabbit_39 Posted October 28, 2004 Share Posted October 28, 2004 Hello, I was wondering if you guys know what maximum angle the CV shaft can take and still rotate. We're not planning on running it an angle, but with 14" of travel on each side (8" in compression and 6" in droop), we're looking at a substantial angle (like 30-35 degrees in compression and 20-25 degrees in droop). Normal driving, the axle will be close to straight, it'll only need those angles when we're jumping or landing hard. I'm thinking if they last 250 miles, we're happy. The competition is a 100 mile enduro and a 4 hour enduro, plus tractor pull, hill climb, drag race and rock climbing. Thanks to Jason from this board (bajavwnsoobnut) we have the differential from an '83. Would any CV joint from the 80s bolt up? We don't care about the length as we'll cut/weld as needed, we just care about what years will bolt up to this differential. Also, please let me know if you guys know of anyone selling axle shafts that will fit this differential and the driveshaft that will fit this differential. Thanks a lot, Andre S PS: this is what we're building: http://psubaja.spymac.net/ Quote Link to comment Share on other sites More sharing options...
mikie Posted October 28, 2004 Share Posted October 28, 2004 Subaru inner joints max is 23.5 deg from straight, giving 47 deg total angle change. From my experience any rear leone axle will fit the rear diff spline, but my experience is limited and others here may know better. Quote Link to comment Share on other sites More sharing options...
BobBrumby Posted October 28, 2004 Share Posted October 28, 2004 basically turbo 4x4 front axles have 25 spines on the tranny stubs and Na have 23. btw 2wd have smaller joints i think. Apprently the hub side of the axle is the same thruout. And rear axles are the same regardless of turbo/Na. And I think ea82 axles are a little longer than ea81. Quote Link to comment Share on other sites More sharing options...
