Dazed Dreamer Posted October 28, 2004 Share Posted October 28, 2004 On my 93 sedan there is a noise when I turn comming from my right wheel like a knocking noise only does it at certain speeds and on turns but not on turns from a stop but like a long turn on a winding road it was doing that on my left but i guess the lug nuts were just lose (i dont know who or why they were loose) but yah I tightened them and it stopped but last week I noticed my right side started but they arent loose can somone help me out on this? Link to comment Share on other sites More sharing options...
Dazed Dreamer Posted October 29, 2004 Author Share Posted October 29, 2004 please help somone? Link to comment Share on other sites More sharing options...
brus brother Posted October 29, 2004 Share Posted October 29, 2004 Do the boots CV joints appear intact or is there a tear that could have allowed the grease to become contaminated or degaded to the point where the joint is trashed? Axle nut loose? Ball joints? Steering rack? These are the suggestions I've seen on the site in the past. The Search function IS your friend! Also check out "Similar Threads" at the bottom of this web page. For many issues, the guys and gals on this site have "Been there, done that AND bought the T-shirt". Link to comment Share on other sites More sharing options...
Dazed Dreamer Posted October 29, 2004 Author Share Posted October 29, 2004 Yah I hsould go back to using searches I just grew lazy over time the CV joints are intact and all but when I did the engine swap for some reason the right side came out of the transaxle we made sure not to contaminate the greese at all when putting the berrings back in place lost some greese but there was still alot in there it seemed and I dont think the CV joint is the right part im thinking but it it connects the same way except to the transaxle and we used hose clamps instead of the normal clamps to clamp the boot back down I dont know if that changes anything I also hope you understood all that up there I also noticed when the wheel drops like goin over the dip into my circle it now makes the noise Link to comment Share on other sites More sharing options...
Log1call Posted November 2, 2004 Share Posted November 2, 2004 Hi, could be a wheel bearing, try jacking the car up and grabbing the wheel top and bottom and seeing if there is any play when you try to rock it in and outwards. Let us know what you find. Link to comment Share on other sites More sharing options...
Dazed Dreamer Posted November 4, 2004 Author Share Posted November 4, 2004 Hi,could be a wheel bearing, try jacking the car up and grabbing the wheel top and bottom and seeing if there is any play when you try to rock it in and outwards. Let us know what you find. Yah out of instinct that is the first thing I did heh its pretty tight no movement now it doesnt make noise on turns as much but sometimes it does when im goin straight not all the time and mostly at low speeds Link to comment Share on other sites More sharing options...
