October 30, 200421 yr Cruisin' another board I discovered that you can open the Subaru hood to a complete upright position! The hood prop can be removed from the front of the engine compartment and positioned into a hole in the front of the passenger side strut tower (covered with a plug on some models). Darn handy especially when working towards the rear of the engine.
October 30, 200421 yr we like to call that the engine removal position. it makes it so much better to do stuff under the hood with it up like that -mike
October 30, 200421 yr If you use a socket set (metric) you can achieve what I call the "hood gone" feature. Tons of room and no pesky rod in your way. Lots of light gets in too. Hope this helps.
October 30, 200421 yr Love this feature. However, no-one has mentioned another major advantage: It's a Mercedes competitive feature, so when someone is dissing Subarus you can mention that only Benz and Sube hoods can do this! I also like to declare that I want a car with a boxer engine and four-wheel-drive. My wallet makes the Porsche vs. Subaru decision! By the way, get your hands on the previous model S-Class Benz and open the hood to 90 degrees. HOLY SMOKE! It's like standing next to a high rise building, the hood is SO long!
October 30, 200421 yr Author WARNING: Never use the aforementioned hood position while driving as it will severely and adversely affect aerodynamics and increase gas consumption.
October 30, 200421 yr yeah it's a nice feature. here's a pic from the donor car http://www.surrealmirage.com/subaru/images/swap/02/DCP_3065.JPG
October 30, 200421 yr WARNING: Never use the aforementioned hood position while driving as it will severely and adversely affect aerodynamics and increase gas consumption. I put a plexiglass window just in the center of the hood on my car and rigged the hood latch with a special spring and cable release. I use it as an emergency brake when there's ice on the road. Honest!
October 30, 200421 yr I think my 94 Acura integra had the ful open hood as well. I am pretty sure most Hondas have it as well (Honda=acura).
