tune up questions
i am getting the loyale a tune up today (90 loyale 4wd 221,000 miles 5-sp). i know i have seen people recommend different plugs, wires, etc. on the board but i can't seem to come up with what i'm looking for with a search. so, what should i get for everything i need for a tune up? thanks. i don't know if this car has ever had a tune up, i know it hasn't in the last 50,000 miles that i have owned it. i am hoping it will have an affect on the performance a little. what should i expect?
you can't go wrong with anything from NGK (plugs and wires) (the wires have the correct resistence and are cut to the exact length)...for the dist.cap and rotor I have been using Napa products...its cheaper then from the sub.dealer while at the same time still made to the same standards as the dealer product.... as for improved performance, any tune up will help, but it really all depends how bad it was running before
also k-n filter , cut out the bottom of the air box , check all vacuum hoses , run injector cleaner though[ chevon stuff]
Don't waste your money on a K&N filter. The only time that will start to help anything is if you've already got at least a better exhaust on it. A better and cheaper mod is to just cut out the bottom of the airbox, as the stock intake tract is quite restrictive.
