suspension with height control
Hello
could someone put the link for suspension with height control. I have a GL with carb and i will like to change the old suspension.
Is it posible to change?
Nebivedu
yes you can change the air suspension ,my rear air struts went out first , then my fronts, [ leaks] in my opinion change them ALL , it will make it alittle rougher riding but aleast you can drive it , mine is a 88 awd a/t turbo wagon
I have regular suspension. I would like to change it to air suspension with small addition - strings. I will change the lover side of struts and put strings on and fill them with air. Is it possible to do something like that?
Nebivedu
Nebivedu
If I understand correctly, you want to put metal springs on to the air suspension struts? This is difficult because the struts do not have any mount surfaces for the springs.
I know that there is no mount surfaces. I will do it. I have 8 pieces of air suspension struts (4 back and 4 front). Here in our country the GL costs aprox 50 dollars in your currency. I bought 4 and i will dismantle all of them. I get a new machine - only 67.000 kilometers driven(40000 miles) in one of them - it is already in my car.
Nebivedu
Nebi, it appears that some of these guys mis understand you intentions.
Most people over here take the air suspension off and replace
it with normal springs and shocks/struts.
You may want to look at this post for more info
on using air suspension
http://www.ultimatesubaru.org/forum/showthread.php?t=25305
As for adding springs also, sounds interesting.
Let us know if we can help.
Hope this helps
Thanks. You helped a lot.
Nebivedu
