November 21, 200421 yr Hi everybody, it's my first time here but i think this site is huge and i've seen so much tech tips from people that look to know wat they're talkink about....Anyway, i got a loyale 4wd 93 and want to know why my sister's one is a lot more powerfull than mine. She got a 92 and her car is going almost twice faster and look to have more torque. I would like to know wat changes should i make to get this power or wat's going on???? Thx very much.. down.
November 21, 200421 yr I would like to know wat changes should i make to get this power or wat's going on???? Thx very much.. down. Start with the basics: Change filters (air, fuel), Replace spark plugs/wires, distributor cap and maybe ignition coil. Replace PCV valve Check all your vacuum lines and if they are old and brittle, just replace them. If clamps are loose, tighten. See how things go from there.
November 21, 200421 yr first ? how many miles on both also you can give yours a good tune up new cap, rotor, plugs, wires, air filter, fuel filter this my help you get back some power
