November 26, 200421 yr I just got in from doing some shopping.Bought a new jack and picked up the Marvels Mystery oil for my Tick of Death. Dumb question of the day...How long should I leave it in for..regular oil change time or should I run the car for a week or two then change it out?? See???? Like I said ..Dumb question right?
November 26, 200421 yr Leave it in until the next oil change. One of the proponents of MMO says he needed to include it in oil changes for a year before the lifter noise finally subsided.
November 26, 200421 yr Its a good oil detergent. Keep using it until the tick stops. Dont forget to change oil/filer reguarly (2000~3000 miles) and use QUALITY oil....either MObil 1 snythetic, or the Castrol GTX.
November 26, 200421 yr leave it in and keep adding it. it's not very much, so it's no surprise it will take awhile to do anything sometimes, if it does. i've used 2 quarts before and even 2 quarts of ATF in my current 205,000 original miles XT6 with no problems. absolutely no tapping from this thing, not even a little in cold weather or idle or whatever. i run Mobil 10w30 all year. original oil pump and everything else. machine shop that rebuilds alot of motors and heads in my area said that even regular oil with frequent enough oil changes will gradually *clean* your motor...but i bet that takes a long freaking time so i wouldn't count on that getting you anywhere. but once you get rid of the tick, keep changing your oil frequently for that reason and you should be good to go. you changed the oil pump seals already? is the tick coming from all around or one particular side or one particular cylinder? have you already diagnosed all of this?
