seth3030 Posted December 4, 2004 Share Posted December 4, 2004 how do i replace my rear cv joint on the drivers side? i just got it out of the rear diff now how do i get it out of the rear drum break, do i hit the pin out just like on the rear diff side? Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted December 5, 2004 Share Posted December 5, 2004 to remove a rear axle, first remove the roll spring pins, using a 3/16 ROLL PIN punch, one for each end then disconnect the dif side, then disconnect the wheel side Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted December 5, 2004 Share Posted December 5, 2004 I believe if you jack up the car to take all the weight off the tire, the CV will come out after removing the pins. If it hasnt been removed in a while it may take some effort to break it loose from the rust and grime around it. Quote Link to comment Share on other sites More sharing options...
