December 17, 200421 yr My passing lamp wont work on my GL. it says its on all the time, but it isn't. I know the bulb isn't burnt because it turned on for a second one time.
December 17, 200421 yr sounds like an ugly, fuzzy, green, brittle wire, or plug crappin out. id check the wiring for obvious uglyness first off.
December 17, 200421 yr check the fuses and look for the evil greenies while you're at it, check the grounds
