December 22, 200421 yr http://www.oly4x4.com/4x4calculators.htm Transmis Ratio: 3.307 TransCase Ratio: 1.592 Axle Ratio: 3.9 "Crawl" Ratio: 20.5325016 Seem's pretty wussy when I was talking to a guy yesterday about Land Cruisers while looking at some Subaru's he was trying to get rid off. He was boasting 300+ "crawl" ratio Said it was more than you'd ever need but did it anyway :-p What kind of #'s are you t-case mod duders pulling? Is this the only real viable way to improve our gearing? Honestly this was the first thing I noticed when I got out on some real trails in 4Lo after the lift and tires.... I wanted another Lo range !_!
December 22, 200421 yr Lets see here, this is what I have with my dual transfercases.... Transmission Ratio: 3.954 First TransferCase reduction box Ratio: 2.28 Second TransferCase reduction box Ratio: 4.70Axle Ratio: 5.29 "Crawl" Ratio: 224 ish Oh wait, you where talking Subies huh.... well my Subie is the same as yours mogan........ 20 ish : 1 .... :yuck: Sure my Toyota seem's pretty low but there is still time I wish I had 300 ish. But the smaller the tire the less distance you are going to travel per revolution. But another way to look at it might to be to comapre actual feet travel per minute. This is an unfair example but it will give you the equation of rthe subies...... With 800 rpm * 36" tire * 3.14 / 12 in/ft / 224:1 = 33.6 feet per minute at idle. Now in a Subie at 800 rpm* 28" tire * 3.14 / 12 in/ft / 20.5:1 = 293.2 feet per minute at idle. Anyways sorry for the rambling.... its just this 20 ish crawl ratio makes me laugh.....
December 22, 200421 yr Anyways sorry for the rambling.... its just this 20 ish crawl ratio makes me laugh..... Subies don't crawl..... they dance!
December 23, 200421 yr Author I meant dual t-cases on SUBARUS singletrack: and what good little dancers they are BUT I want a lower low range still
December 23, 200421 yr first gear is 3.5 something I believe on the 5spd so mine is first gear: 3.5 (ish) low range: 1.592 second case: 2.1:1 final drive:3.9:1 =45.6:1 on 31" tires, which I am happy with. In double low I have enough control to navigate any situation I can think of on the island (mostly fitting in tight spots between trees, bedrock climbs, riverbeds, and dirt/gravel) Plus just running my second case in low gives me 29:1 which is great for mud or loose climbs cause it gives me speed and keeps me in the 3-5k powerband. I guess thats 160ft/min.
December 23, 200421 yr Interesting. I used the calculator to figure out the difference in MPH if I changed the RX tranny to 3.9 from 3.7. At about 3000rpm in 1st, there is only a 1 MPH difference and at 4000rpm in 5th there is only a ~4 MPH difference. Makes me wonder if it is worth doing. I think it would be better to have the 1.592 low range and keep the rest the same, 3.7. This would make for some great 0-60ish times with the turbo. Jay
