mtnman38 Posted December 26, 2004 Share Posted December 26, 2004 HEY FOUND THIS CARB ON eBAY TODAY hERES THE PROBLEM i CURRENTLY HAVE TWO OF THESE CARBS(IN HOPES OF PUTTING THEM ON MY HATCH) The carb is from a ford escort of festiva and some chevys they were replacement carbs for the stock apps, I called weber to try and find a rebuild kit and they no longer make it. I tried even the ford/chevy dealers and they had no input(as usaul) so if anyone is thinking of purchasing you might want to reconsider. once it goes youll never be able to rebuild it O yea the linkage is on the wrong side too If anyone knows any diffrent I would surly like to know so I can use the ones I have dft 11a 32x34 Thanks LT Quote Link to comment Share on other sites More sharing options...
naru Posted December 26, 2004 Share Posted December 26, 2004 HEY FOUND THIS CARB ON eBAY TODAY hERES THE PROBLEM i CURRENTLY HAVE TWO OF THESE CARBS(IN HOPES OF PUTTING THEM ON MY HATCH) The carb is from a ford escort of festiva and some chevys they were replacement carbs for the stock apps, I called weber to try and find a rebuild kit and they no longer make it. I tried even the ford/chevy dealers and they had no input(as usaul) so if anyone is thinking of purchasing you might want to reconsider. once it goes youll never be able to rebuild it O yea the linkage is on the wrong side too If anyone knows any diffrent I would surly like to know so I can use the ones I have dft 11a 32x34 Thanks LT Don`t know who you were talking to but a 60 second goggle search shows lots of kits. http://www.piercemanifolds.com/Repairkits.htm http://www.carburetion.com/Weber/weberparts.asp Quote Link to comment Share on other sites More sharing options...
mtnman38 Posted December 26, 2004 Author Share Posted December 26, 2004 Hey I STAND CORRECTED this is awsome now I can rebuild them both for 60 bones SWEEEEEEEEEEEEET!!! DISREGUARD WARNING ON EBAY CARB BUT LINKAGE IS STILL IN THE WRONG SIDE BUT SOULD BE EASY TO FAB Quote Link to comment Share on other sites More sharing options...
edrach Posted December 27, 2004 Share Posted December 27, 2004 DISREGUARD WARNING ON EBAY CARB BUT LINKAGE IS STILL IN THE WRONG SIDE BUT SOULD BE EASY TO FAB If you have the power steering setup you might want to have the linkage on the other side since the weber seems to interfere with the power steering reservoir. Quote Link to comment Share on other sites More sharing options...
