January 4, 200521 yr I'm trying to locate my blower motor in the EA81. Best I can find is a brass-colored cylinder w/ a small hose going into the back of it. Is this the heater blower motor? I can't see any wires going to it and I can't see any screws to remove it. Any help would be appreciated. Also, does anyone have a ballpark estimate of what a replacement from a parts shop costs? Thanks.
January 4, 200521 yr yea, that sounds like the blower motor. On the 82s, there are a few screws that hold it in place. good luck
January 4, 200521 yr Author The Haynes Manual that I have (doesn't cover the EA81's like I was assured it would) shows something that looks quite different than what I'm seeing here on my car. I went to remove the Glove Box but couldn't figure out how. And once again my manual is useless.
January 5, 200521 yr I don't think what you found is what you are looking for.... the motor is black, and about fist size... to get to the blower motor, you need to do the following (and probably more) on the passenger side: remove tray under glove box remove glove box remove kick panel trim piece see big black box that connects into the AC condenser coils? it's on the back side of it. you need to remove that whole black box unit to get to the blower motor. replacement ones are usually around $60 at NAPA...
January 5, 200521 yr Author McBrat - Thanks a lot for the description. I'll take a look at it tomorrow. Later,
January 5, 200521 yr Are you referring to your heater control unit? I just purchased one for $35.00 from used-carparts.com (plus 2 day shipping) and had my mechanic install it. Apparently, you can actually order a new one from Subaru for around $199.00. I'm glad I had the whole heater control unit replaced because now I also have a working cigarette lighter (I don't smoke) so I can actually use the lighter as a battery charger! The mechanic tried to convince me to replace the fan because it didn't blow super fast, but I figure if the car doesn't run really hot so if the fan runs any faster it still won't blow any hotter.
