January 9, 200521 yr Hi All. I got an 1984 Subaru sportswagon and i can't seem to find the plug to bridge to get the codes. I was wondering if anyone could help me. The car... 1800 EA81/EA82 motor R/H drive Carby
January 9, 200521 yr It is generally near the computer. As was pointed out in your other post it will probably be up under the dash(computer for RH drive) and green in color(plug). It is a single wire in and out. Plug it in and look for the flashes from your computer LED.
January 9, 200521 yr Author When i find the plug i just use a paperclip and bridge the connection dn't i and then watch the check engine light flash at me? Coz i was driving today and the check engine light went on while driving so i know there is a code but wat is the most common code related problem with the 84 sportswagons.
January 9, 200521 yr No paper clips!!!!! Just plug it in to the matching green connector. Couldn't tell you what the common codes are for an Australian Subaru as many things are different from ours.
January 9, 200521 yr Author Cheers mate Thanks 4 ya help. Now i can go have alook and see wat i am lookin at having to replace.
January 9, 200521 yr Aye, mate have a read on this - might help It's from the repair manual listed on the top of the page (USRM) Reading Error Codes
