January 25, 200521 yr Help, I can't find a piston stop(for a sub, just Ford and Chevy:rolleyes: ) in this whole town......... In fact I only found one guy at a parts house who knew what I was talking about!!! If you have a lead on where to find one please let me know. Thanks, Tim
January 26, 200521 yr Author Okay, I found a couple doing a Google search. It is basically a threaded rod that you screw into the spark plug hole to stop the piston on it up stroke. Rotate the engine till it stops, mark the flywheel. Rotate back the opposite direction till it stops, mark the fly wheel. The point inbetween your two marks is TDC, then just set your timeing using a timeing light and the TDC mark. Just to be sure, Subarus use a 14mm spark plug, correct??
January 26, 200521 yr Okay, I found a couple doing a Google search. It is basically a threaded rod that you screw into the spark plug hole to stop the piston on it up stroke. Rotate the engine till it stops, mark the flywheel. Rotate back the opposite direction till it stops, mark the fly wheel. The point inbetween your two marks is TDC, then just set your timeing using a timeing light and the TDC mark. Just to be sure, Subarus use a 14mm spark plug, correct?? i think the EA82's use an SAE thread....im not sure.
January 26, 200521 yr i think the EA82's use an SAE thread....im not sure. nope 14 mm just like most other cars on the road. domestic too. sorry no leads on a piston stop. you could just make one or use one for another aplication.
January 26, 200521 yr nope 14 mm just like most other cars on the road. domestic too. Right. 1.25 thread pitch, 14 mm diameter.
January 26, 200521 yr http://store.summitracing.com/eproduct.asp?N=120+%2D42157+%2D42158+309974 This one is the one I'm most familiar with.
January 26, 200521 yr http://store.summitracing.com/eproduct.asp?N=120+%2D42157+%2D42158+309975 Damn I'm on a roll.
January 26, 200521 yr Here's one if you have a head off. http://store.summitracing.com/eproduct.asp?N=120+%2D42157+%2D42158+309976
