February 21, 200521 yr Hello, I have an 88 subaru GL? 4WD sedan w/52,000 miles on it. Lately my auto trans has been acting up so I replaced the fluid and filter but to no avail.... The problem is when the car is in drive and you take of from a dead start the car will shift to 2nd gear and then shift to 3rd gear about 3 seconds later. It is in 3rd gear by 10-15mph. which then makes the trans slip. If I shift the car manually it sometimes shifts fairly solidly but sometimes it does slip a small amount between gears. Any Ideas?????
February 21, 200521 yr The early shift out may be a problem with the vacuum modulator (on vac line to it). The 3AT is also know for problems with the governor, try a search to see if any of your symptoms are similar to what other have seen. Gary
February 21, 200521 yr Here's the link to the repair page on the old site: http://www.usmb.net/repair/?CurrentDirectory=FOLDER_3f29b58f50d9b8.15492800/&FileType=Article&File=ARTICLE_3f57fdb83de231.34713659.art Hope that helps Gary
February 21, 200521 yr And here is a link to an article on how to replace the vacuum modulator http://www.ultimatesubaru.org/forum/article.php?a=21 Make sure you rate the article high
