scrapdaddytatum Posted February 25, 2005 Share Posted February 25, 2005 factory ride, ea82t, no mods, idles high, about 1200, 4eat, no other real issues, how do you adjust the idle on these???? Quote Link to comment Share on other sites More sharing options...
Ross Posted February 25, 2005 Share Posted February 25, 2005 Should be a vertical recessed flat head screw at the front of the throttle body. Quote Link to comment Share on other sites More sharing options...
calebz Posted February 25, 2005 Share Posted February 25, 2005 Should be a vertical recessed flat head screw at the front of the throttle body. Close, but its on the rear of the TB;) Quote Link to comment Share on other sites More sharing options...
tizzle Posted February 25, 2005 Share Posted February 25, 2005 aren't you supposed to remove some purge line while adjusting that? Quote Link to comment Share on other sites More sharing options...
Skip Posted February 25, 2005 Share Posted February 25, 2005 J, If a simple adjustment of the idle control screw does not bring the idle speed to spec.. Please verify i) The throttle/cruise control cable is not too tight. ii) The throttle stop screw has not been changed (throttle plate should all but close completely on a fuel injected car.) iii) The dashpot is not hanging up iiii) That the idle switch in the TPS is closed at idle. iiiii) All vacuum lines are connected properly and there are no leaks (a small vacuum leak will raise the idle speed) Quote Link to comment Share on other sites More sharing options...
