MY81Wagon Steering Lock/Ignition Switch Removal
Is it possible to remove the steering lock (Ignition switch) from the column ?
2 screws are phillips head and the other 2 are blanks. Is there a way to remove them ?
Many thanks
The two with the broken off heads are very easy to remove. You need to start them with a small, sharp chisel and hammer and they will screw right out.
you can use a cutting wheel, a file, or hacksaw blade, or similar tool to make a slot on the headless bolts to turn them out with a flat screwdriver
thanks a mill, worked like a charm.
