March 11, 200521 yr I Want to put the instrument panel from a Gl (has a tach) to my Dl (no Tach) Are the plugs on the back the same or do i have to change some wires about?
March 11, 200521 yr Worked on the older '80's decade, but you had to change the oil pressure sender to make the guage work.
March 11, 200521 yr Author In the carb to spfi conversion manual, it states that the wire for the speed sensor is ini different positions between the Tach version and the version without tach, does somebody have a diagram with the pinouts of the plugs???
March 11, 200521 yr don't just change the IP, if you bring the wiring from the other dash most of it works, and i'm sure all of it will, once i get the wiring done, btw, yeah i've done it.
