I had a Setback,.. But then an Idea!.. MPFI conversion with carb heads??
I was considering the carb to spfi conversion, but somebody from ausubaru.com told me that the spfi wasn't released in Aus.
:banghead:
Soooo.... why not drill holes in my carb manifold, just before the heads, put in the mpfi injectors, ecu, fuel pump, disty and adapt the throttle body to where the carb bolted on and presto,.... MPFI:brow:
Has it been done, can it be done, what could be my major setbacks ????????:banana:
You know what? I have no clue if it has been done, or the setbacks...I do know that you should do it! That'd be sweet! :headbang:
[HTi]Johnson
Thanks for the support,. i cant see why it wouldnt work, it would be the same as the spfi conversion, only with 4 injectors mounted on the ends of the intake and modified to bolt the throttle body and tps onto
(I also can't see why it couldn't be turbo'd):brow:
But I need way more information first, and money
sounds good
not sure how a stock form of injection ecu might work with the offbeatsetup
so you might need to got either aaftermarket or do it yourself . universal.almost type injection like i run
Arent the MPFI injectors mounted at the end of the intake, just above the head,... this is where i was planning to put my injectors, only i will have 2 in each end.
How more comlpex is the MPFI over the SPFI system. Can it be compared to the SPFI in the carb to spfi canversion manual.
Could i use non subaru parts (dont throw rocks at me, i just wanna save money)
see'ing that i need to make up an intake adaptor, could i use a different throttle, ecu, injectors, fuel pump and make them work with the subaru disty?
no big deal. just use the flapper mpfi system subaru used in 85-87 cars. it used a vac operated standard distributor. the fuel injection was just that, controlled the fuel, not the spark.
drill for the injectors and do it up! =]
Is the 87> system much more comlpex, wouldn't elect controlled spark be better,.. better advance curves???
These are the parts needed for the spfi conversion (i assume the MPFi will be the same, only with 4 injectors)
ECM
Wiring harness
Ignition and fuel pump relays
Fuel pump
intake manifold
MAF
Coil and disty
O2 sensor
Anything I have missed out???
the flapper system is very easy to wire, and afaik, its less complex, because it uses the optical disty.
i like my flapper, but my er27 is a hotwire, with the optical.
Is there anyone who has attempted this before???
Are there any guidelines I have to follow on the placement of the injectors???
With the 85-87 set up, it wont matter so much how the injectors are mounted (not so much as in the later ones, anyway). You will want to find some pics of where they are normally mounted, and mount them in a similar place. The angle is quite important. I think its about 20 degrees or so to the direction of flow, but again, have a look at how they are mounted on the real thing, and copy it.
I could sell you my SPFI conversion stuff that I have collected for my EA81 spfi conversion- (manifold, ECU, wire miniharness (needs to be made into a harness and I have the diagram) and a disty (needs to be modified for ea81)
i dont know if shipping would be too bad for an intake and things...
