March 18, 200521 yr i found a 88 gl-10 w/ LSD is there a difference in driveshaft length between LSD and non-LSD. will it bolt right in to my 88 gl-10T they are both 3.7. is there anyting else i'm not thinking of?
March 18, 200521 yr Yup, will bolt right in. I have an LSD from an 88 turbowagon in my 87.. easy swap
March 18, 200521 yr Author how hard would it be to swap the 5sp manual w/ center locking into my 88 gl10t w/ auto tranny would it just be bolting it right up then the clutch pedal and cable? also is $75 alot for a 88 rear diff LSD and how much should it cost for the 5sp manual w/ center locking diff
March 18, 200521 yr 75 bucks is on the cheap side. people are selling them for 200+ everything can be made to fit, there are guides to converting the differential to a 3.9 instead of the 3.7 that it is, but if you swap the diff lock tranny in you won't have a problem.
March 18, 200521 yr how hard would it be to swap the 5sp manual w/ center locking into my 88 gl10t w/ auto tranny would it just be bolting it right up then the clutch pedal and cable? also is $75 alot for a 88 rear diff LSD and how much should it cost for the 5sp manual w/ center locking diff The auto to manual swap is a lot of work, but none of it is difficult. I swapped the 4eat in my 1990 Loyale turbo for a single range w/center locking diff. Every thing bolts right up. $75 is a good price for the LSD diff. I got my single range diff lock tranny for $100 from another board member here in CO. If I remember right you'll need the driveshaft and tranny crossmember from the manual car. Good luck!
March 18, 200521 yr any of you guys want to part with your 4eat tranny's, my wife won't drive a stick and I would like to have one as a spare. Thanks Mike
March 18, 200521 yr Author i would get rid of mine when i get the 5sp center locking diff let me know if your interested
March 18, 200521 yr lol.. funy you mention the tranny.. whenI did my LSD, I also installed the 5speed with locking center diff.. I had already done the auto to manual conversion a year prior, so I didn't have much to deal with.. Its not too hard at all.. jUst remember to get the pedal box too.
March 18, 200521 yr I would be very interested. When do you think you wil have it availabel and how much do you want for it? Mike You can call me 804-393-0516 i would get rid of mine when i get the 5sp center locking diff let me know if your interested
