March 23, 200521 yr ive seen a few of you guys say in your sigs that you are running gm alts, im kinda curious about doing this since i still have the one i pulled off my astro, and it was only 6 months old when i pulled it off. it came from an astro with all the power goodies so i imagine it is fairly high output. im curious what kinda mods do you have to do to make it fit. since i had been stripping my astro i have all the plugins for it as well, i know i will need to change the pulley over to a v-belt 1. but other than that what mods do you have to do? if you got any pics it would be appreciated. ill have to double check but im pretty sure my alt has an internal cutoff(or whatever the voltage control part is) but ill double check to be sure.
March 23, 200521 yr I have this kind on my jeep and its horrid if it gets muddy I have to sit there and hose it out for it to work again. it was never the same after the first time either.
March 23, 200521 yr Author the brackets on the first one look the same but the, overall style of the 2nd 1 except for the bracket is closer to what i have. i never had a problem with the alt working after i got it muddy and believe me it got muddy lol my engine bay usually stayed muddy. my astro was my last mud runner dustyrider ty for the link im gonna check it out after i do this post
March 23, 200521 yr Here's another link to a gm alternator swap. http://www.ultimatesubaru.org/forum/showthread.php?t=15473&highlight=alt+swap
March 24, 200521 yr Author thanks for the great links guys! sorry to bring up an old topic, da$% i need to learn to use that search button!!! lol i double checked at the astro site and its a 105a output on it so when im ready to add some lights and whatnot that should be more than enough power
March 24, 200521 yr I have this kind on my jeep and its horrid if it gets muddy I have to sit there and hose it out for it to work again. it was never the same after the first time either. This type is sensitive to things like jumpstarting and such. They are easy to burn out. I'd avoid these.
March 24, 200521 yr Author well im gonna go up to my storage area tomorrow and get it so i can double check it, but like i said b4 i never had a single prob with it, and i did alot of jumpstarting with it since i had a car with a battery that kept going dead. but ill look tomorrow to be posative about which 1 i got, i know the fins are the same on that 2nd 1. i may not technically have either of them
