March 24, 200521 yr Heres what is going on. I was in the car waiting for it to warm up. I was watching the tach go from 800 to 1300 and up to 1800 RPMS every few seconds. I opened the hood and heard a strange sound. I tracked it down to the distributor and you can feel the distributor when the noise and tach changes. It feels and sounds like a grinding from with in the distributor. I opened it up and found nothing weird, (new cap and rotor) no scratches on them. Can this be the vacuum advance unit malfunctioning? I hope someone can help on this one. I have the timing set correct and I looked for and used soapie water to find any vacuum lines that might be bad, but couldn't find any. I have tightened the bolts on the carb,about 1/4 turn each. Didn't make any difference.
March 24, 200521 yr The bushing in your distributor is probably going bad. Take off the rotor off and wiggle the end of the shaft. Up and down play is okay but front to back and left to right isn't.
March 24, 200521 yr Author Did that and found it to be tight. I am going to check the timing again this morning and see if it's off. For some reason I can't remember removing the vacuum when I timed it last time. Could not removing it cause it to do this? And the advance is trying to adjust when it doesn't need to!
March 24, 200521 yr k well pull the disty from the car.. remember the exact position of the rotor, so when you put the disty back on the car, you get the timing right. Now turn the disty by hand. It should spin without and binding, rubbing or grabbing. IF it does, the bearing/bushings are bad in the disty
March 24, 200521 yr Author I will give that a try if after I re-time it this morning doesn't work. Thanks guys for your input.
April 10, 200521 yr I will give that a try if after I re-time it this morning doesn't work. Thanks guys for your input. what is happening with your charging???? altenator charging too high?? one time I had my tach jumping for joy all the time.....lol....sometimes after I turned the ol heater fan on...... I changed the starter and voila...prob solved...so many little things that can happen..... would check the altenator first....lol...
April 10, 200521 yr what is happening with your charging???? altenator charging too high?? one time I had my tach jumping for joy all the time.....lol....sometimes after I turned the ol heater fan on...... I changed the starter and voila...prob solved...so many little things that can happen..... would check the altenator first....lol... sorry changed the altenator not starter..lol..
April 10, 200521 yr if the tach is jumping i.e. engine rpm staying constant. i would suggest bad grounding in the electrical system check the earths where they connect to the chassis otherwise there could be interference in the electrical system
April 10, 200521 yr Author Thanks for your replies, I did get the car fixed, it was the distributor that was bad. All is good now.
