91 Legacy wagon 2.2L missing when started
  • 4 months later...
Only missing when it is started? that sounds like a faulty temp sensor (the two wire one that feeds the ECU) giving false readings that say that the engine is already warm, when it is not. Just a wild guess though, without the codes in question.
I would think it must have something to do with I.A.C. being it runs fine after warming up.
More then likely the coolant temp sensor is bad. It's almost a tell-tale sign that the CTS is bad when the car runs bad when cold but ok when warmed up, or vice-versa.
