April 6, 200521 yr I bought some center caps from a member of the board, and they won't work for my car. I spent an hour cleaning them up because they had black overspray on them, and then took them out to put on the car and they won't work on the back rims with the drum brakes I could make them work for the front rims if I bend the tabs out, but what's the point if you can't put on all 4? What a waste of money :-\ Anybody need some stainless center caps? All shined up and nowhere to go.......
April 6, 200521 yr do you have the plastic rings to go with them? they are necessary for mounting the center hubcaps
April 6, 200521 yr Author do you have the plastic rings to go with them? they are necessary for mounting the center hubcaps The person I got them from said they weren't necessary with these? Maybe I should post a picture......
April 6, 200521 yr if you could that would be great - I had the old "wagon wheels" before I switched to aluminum alloys - had to have the rings - don't know for sure about the other steel rims - problem was, most shops around here are VERY sloppy, and they were broken almost every time the car went in the shop for anything to do with the tires
April 6, 200521 yr Karin, some do and some don't. Sounds like you have the older style gen2 wheels. They should take the plastic rings.
April 6, 200521 yr this goes in line with what i just went through...got some chrome center caps from austin and from the pap, some chrome trim rings from the pap, and some acorns from the pap, shined everything up nice and........front chrome centers went on fine but the rears wont...brian the guru says they will fit the wgn wheels but not the normal steelies in the rear.... so, i too have extra chrome center caps, am now looking for one more trim ring and four baby moons btw, brians had some of those plastic thingies...
April 6, 200521 yr Author Using EA81 center wheels don't always work on EA82 wheels on an EA82. So, those are EA81 center caps then? Ugh, I am sure I said I was looking for ones for an EA82
April 6, 200521 yr ha! i've got two different styles of center wheels, one with long prongs like your pic and one with much shorter prongs and it still wont fit on the rear...
April 6, 200520 yr You may need the plastic ring that goes in the center of the wheel to get them to fit the back.
April 6, 200520 yr as mentioned, we tried that on the rear also, still wont fit..brian thought they might fit on the wgn wheels though...
April 6, 200520 yr actually those are fro the steely wheels i think i have a set of the same exact ones on the 87 hatch i just bought and its got the steal wheels on it, i tried to see if they would fit on my wagon wheels on my 85 wagon and they wont fit still have the same clearance issue on the back tire. the ea82 ones are shorter prongs with a fatter top piece on them i can get a pic of that type if you want to see what they look like if you want to see the type of wheels i have those type on look at my post (my new 100 sooby)
April 6, 200520 yr hmm, those wheels look like mine..yeah, a pic of those rear center caps would be nice, especially a pic of those prongs
April 6, 200520 yr the first pic is of how my steal wheels on my hatch are set up they have that big metal lip as part of it for those old style ones.so i need no trim ring for that style. the 2nd and 3rd pic of are both side by side, the one that you will want is the one on the left, you need the plastic trim ring for these i believe, or at least i do on my wagon wheels.
April 6, 200520 yr well, i've tried both those styles and no go.... with and w/o the plastic ring thingie
April 6, 200520 yr well i may be wrong on steelies, on my 87 parts car i had the steelies and just had stock subaru hubcaps on them.you could try to find a set of those if the steelies wont accept either center cap. the one on the back tire are the ones i had, had a full set of them but didnt figure anybody would want them so i let them go with the car when it went to the scrapyard, sorry if you had wanted them
April 6, 200520 yr of course, that style of hubcap is exactly what i am looking for ( sheesh, always a little late on catching things before they get tossed
April 7, 200520 yr i seen some pretty simular at walmart the other day for i think it was about $20, hubcaps have really gone down in price unless you are looking for the ghettofab spinner-hubs those are still rediculous, the super walmarts seem to have a better selection for pretty cheap. good luck and sorry if i knew someone might want them i would have hung onto them
