May 10, 200520 yr If im not mistaken, subaru puts the same tranny in the 2.2, 2.5, and the 3.0L versions of their motors, so your tranny should be just fine, unless you start pulling the E-brake and tow it with the wheels on the ground. But if you are truly worried about your tranny, dont do too many mods to the motor. ~Josh~
May 10, 200520 yr the answer to your question is yes. but it's not a very good question. if you are worried about your transmission install an aftermarket transmission cooler. much more efficient than the stock thing that routes through the *reallly cold* radiator. give the trans what they all should have, it's own heat exchanger. best 30 bucks you can spend.
