godwine Posted May 10, 2005 Share Posted May 10, 2005 Anyway to get more horses without blowing the tranny? Link to comment Share on other sites More sharing options...
ballitch Posted May 10, 2005 Share Posted May 10, 2005 If im not mistaken, subaru puts the same tranny in the 2.2, 2.5, and the 3.0L versions of their motors, so your tranny should be just fine, unless you start pulling the E-brake and tow it with the wheels on the ground. But if you are truly worried about your tranny, dont do too many mods to the motor. ~Josh~ Link to comment Share on other sites More sharing options...
idosubaru Posted May 10, 2005 Share Posted May 10, 2005 the answer to your question is yes. but it's not a very good question. if you are worried about your transmission install an aftermarket transmission cooler. much more efficient than the stock thing that routes through the *reallly cold* radiator. give the trans what they all should have, it's own heat exchanger. best 30 bucks you can spend. Link to comment Share on other sites More sharing options...
