richieroo Posted May 16, 2005 Share Posted May 16, 2005 Hey guys (gals!) I need to know how some of you have made the transition to the 5 speed tranny on the cross member. How did you fit a 5 speed into a 4 speed slot! I am going to alter my crossmember for the mounts and want to know about the linkdage as well, but how did you do it? I know I can send my parts in and get them done, but prefer to do it myself. Give me your advice and suggestions and accompished stories! Thanks! Rich 05/16/05 REVISED FROM HERE: I want to know if I put in the orig mounts on the tranny, are they going to be strong enough to hold a tranny that is much MUCH heavier? Otherwise I will have to drill new holes and weld a bit. I can get the originals in there I am just concerend with weight. Rich Quote Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted May 16, 2005 Share Posted May 16, 2005 great write up 5 Speed 4WD D/R Install into 80-84 Body Style good luck Quote Link to comment Share on other sites More sharing options...
richieroo Posted May 16, 2005 Author Share Posted May 16, 2005 bump for revised question Quote Link to comment Share on other sites More sharing options...
richieroo Posted May 16, 2005 Author Share Posted May 16, 2005 double bump! Quote Link to comment Share on other sites More sharing options...
archemitis Posted May 17, 2005 Share Posted May 17, 2005 weight is not a concern =] Quote Link to comment Share on other sites More sharing options...
