June 4, 200520 yr anyone hear about his stuff , goes into motor, tranny, diff, 1 time a year stuff , bonds to metal , i saw a display at anderson;s , very interesting stuff , 2oz per qt of oil or tranny or diff , claims 2-3 mpg more , etc... comments ?
June 4, 200520 yr you would prabably be happier with real oil like royal purple (dyno proven to add power)
June 4, 200520 yr Author yes i am thinking about using royale purple , 20-w50 , but just wanted comments, something i saw
June 4, 200520 yr I had a mechanic recommend that same oil, Castrol 20w50, for my EA82 turbo. How's it been for you? I of course went out and got a case of Mobil 1 and have had to deal with the 5 drips a day since then.
June 4, 200520 yr 20w50 is what i run in my turbo a/t full time 4wd wagon ,castrol gtx Thats what i use as well, i run it in my turbo and my carbed when it was still alive. 20w 50 gives alot better protection on those hot days, Just give it a little more time to warm up in the morning. I used to run valvoline till a fellow subie friend suggested Castrol GTX, My car has never run smoother or quiter, Still like valvoline for my Big blocks tho. ~CHIM~
June 4, 200520 yr Author next time around i think i am going to use 20w50 royale purple , better hp2-3%, 2-3 mpg more, temp of motor 25-45 degrees less ,
June 4, 200520 yr next time around i think i am going to use 20w50 royale purple , better hp2-3%, 2-3 mpg more, temp of motor 25-45 degrees less ,...cleaner,whiter teeth... less body odor... more popular... 15% guaranteed return... I'm a bit of a Doubting Thomas.
June 4, 200520 yr Author it will all depend on the car ,each car will vary , just what i have been reading and talking to people using it , it is equal or better than mobile 1 , there is a board member using royale purple and will not use anything else , forgot his board name , as far as motorkote i was just wondering if anyone else has heard about it , there is a difference in oil ,just like oil filters
