June 12, 200520 yr What size socket would one use on the drain plug of the front differential of a 2000 A/T Legacy. Its larger than 13/16 and 17mm, 20mm perhaps?
June 13, 200520 yr Does it have a squre hole in the middle like the older subarus? Then use a 1/2" drive ratchet, no socket.
June 14, 200520 yr Author found like some sort of metallic sludge on the magnets that are on the inner side of the drain plugs, must be the gears grind up everything metallic that gets shaved off and then it transforms into sludge that is picked up by the magnets, interesting.
